yes, but would be a bit of a chew, also you would need to buy new plastic trim pieces, i.e where the wheel to tilt back and forth is... if its a folding seat then obviously the main handle will be on the inside not outside (I know there is a handle on both sides)... also the seat belt clip would be on the wrong side, unsure how you would move that to the other side, whether its just bolt on or welded?
imo more chew than its worth, especially seens as you can pick up a full set of recaros for a little over 250
