Author Topic: [EDIT: Video Update] Weird movement and vibration  (Read 3116 times)
Offline benmanc
« on: 15 September 2014, 12:15 »
I have a bit of (what seems like) engine movement or something 'moving' or 'rocking'...
If I set off slow up to 3k revs and just let off the throttle I feel some sliding or rocking movement.
Plus when I reverse I have some crazy vibration/rattle going on. No idea if this is related or not.
I suspected it to be the dogbone but just replaced that with powerflex bushes but no difference with the above issues.
Thoughts or ideas?
« Last Edit: 18 September 2014, 08:29 by benmanc »
Offline gm8
Re: Weird movement and vibration
« Reply #1 on: 15 September 2014, 15:17 »
possibly the rear wishbone bushes  ?
Offline benmanc
« Reply #2 on: 15 September 2014, 15:36 »
for the sliding movement or the vibration when reversing thing?
or could that cause both
Offline gm8
« Reply #3 on: 15 September 2014, 15:40 »
could cause both , if they are badly worn they move about quite a bit !
Offline Bellend
« Reply #4 on: 15 September 2014, 15:42 »
CV joints all tight?
Where all my moneys went.
Offline benmanc
« Reply #5 on: 15 September 2014, 17:50 »
will check all this stuff out - dont really know what the hell that sh!t is but will look into it.
Could it be DMF?
Offline Marc87
« Reply #6 on: 16 September 2014, 07:41 »
I had a similar issue recently....knocking when pulling away and stopping and also when reversing. Was expecting the worst and all it turned out to be was the dogbone mount was loose. Tightened it up and it went away
Offline benmanc
Re: [EDIT: Video Update] Weird movement and vibration
« Reply #7 on: 18 September 2014, 08:32 »
Okay just tried rocking the engine and seems to me the nearside motor mount is bust?
Yes?
http://youtu.be/-unbFsh5eQY
Offline Dalo Harkin
« Reply #8 on: 18 September 2014, 12:50 »
looks like its the passenger engine mount is shot to sheet mate  :sad:
Offline benmanc
« Reply #9 on: 18 September 2014, 14:29 »
Going to get some new bolts today (£20 rip off) and a new mount from gsf. Not sure if they are any good though. Although dont fancy paying twice as much from vw
