Golf mk4
Wazzzer
Ignition amp?
Topic: Ignition amp? (Read 1506 times)
johnomk4
Here all the time
Ignition amp?
14 September 2014, 09:55 »
I have a miss fire on number 3. Is it possibly the ignition amp??
viperjsy
Re: Ignition amp?
14 September 2014, 16:42 »
Try changing the coils around and see if the misfire moves and check the spark plugs
johnomk4
Here all the time
Re: Ignition amp?
14 September 2014, 16:44 »
Yup iv done all that, even did compression test
Dalo Harkin
Re: Ignition amp?
18 September 2014, 13:01 »
coil pack wiring?
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
Ignition amp?
