Golf mk4
Wazzzer
Airbag light on
Topic: Airbag light on (Read 2128 times)
Mk2_tel
Here all the time
Airbag light on
12 September 2014, 09:49 »
I have a small steering wheel but I have put the resistor in
I have fitted Audi s3 interior which have airbags so not sure how I turn light off
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Airbag light on
12 September 2014, 11:39 »
depends on what the actual fault codes are?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: Airbag light on
12 September 2014, 12:56 »
you need VAG COM to turn the light off once the fault is logged
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
davidgtrr34
Here all the time
Re: Airbag light on
12 September 2014, 18:33 »
I used a 5w 2.2ohm resistor on the steering wheel and it worked but you need vagcom to turn the light off after you fit it
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Mk2_tel
Here all the time
Re: Airbag light on
17 September 2014, 20:52 »
Mine says airbag tensioner?
Do I need to solder into the loom under the seats???
Golf mk4
Wazzzer
Airbag light on
