Author Topic: Backfire  (Read 1457 times)
Offline Spunky monkey
Backfire
« on: 10 September 2014, 19:38 »
I have a back fire on my 1999 gti turbo golf , It's only after changing up from 2nd to 3rd , the only mod I can c on the car is a dump valve if that helps , any ideas plz
Offline MoMartin
Re: Backfire
« Reply #1 on: 10 September 2014, 21:14 »
When you say dump valve you mean a recirc valve don't you? because atmospheric dump valves are bad news on the 1.8t.
also have you checked to see if you have a decat, because i have heard of some people experiencing back fire with just a decat alone. And it's a mostly unseen mod.
Offline Dalo Harkin
Re: Backfire
« Reply #2 on: 12 September 2014, 13:03 »
could be loads of things causing it, has it always done it or has it started recently?
As Mo said its not uncommon if you have an uprated exhaust
