Golf mk4
Wazzzer
Washers not working
Topic: Washers not working (Read 1601 times)
Lgjennings
Washers not working
06 September 2014, 16:28 »
Hi I've got a golf mk4 1.4e and the washer jets have stopped working. I can here the jets when I turn them on but nothing comes out. I've had ago at trying the clean the ends but still have noticing.
Anyone got any ideas?
Thanks Liam
MoMartin
Here all the time
Re: Washers not working
06 September 2014, 18:37 »
Blockage somewhere in the system is my bet, try using a Compressor to blow the lines through
Perryd84
GTI forum regular
MK4 Golf 1.8T 20V GTI
12 September 2014, 11:47 »
Check the pipe work. Mine was perished and had come apart in the bonnet. Was pissing washer fluid all over the engine when ever I tried to use them.
Just replaced all the pipe work with new silicone.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
WadGTI
Here all the time
Golf GTI'er
12 September 2014, 12:54 »
I would disconnect the jets and then try it and see if water comes out the hoses so you know if its the jets or not.
Golf mk4
Wazzzer
Washers not working
