Author Topic: Speedometer Calibration  (Read 2551 times)
Offline gazza1602
« on: 06 September 2014, 13:26 »
Hey all, I'm just about to replace my alloys with some Audi TT Competition alloys. They are the same diameter but slightly wider. Original alloys are 7J whilst the Audi ones are 7.5J. Therefore the tyres on the new ones will be larger. I was wondering if anyone knew how to recalibrate the speedometer? I'm assuming its not an electronic system due to the age and wondered if it was the old gear system? Hope this all makes sense.
Cheers,
Gaz
Offline gasketface
Re: Speedometer Calibration
« Reply #1 on: 06 September 2014, 15:10 »
i don't think you can recalibrate the speedo but you can use this to get an idea of tyre size you will need :- http://www.miata.net/garage/tirecalcold.html
VW BUSH
« Reply #2 on: 06 September 2014, 18:55 »
Only need to change it if the radius of the wheel is different to std.
Offline Bandit127
« Reply #3 on: 06 September 2014, 19:04 »
Yes, use the same profile tyre with stretch or go lower profile in a wider tyre to maintain the same diameter (within 2%).
Both will keep your speedo accurate.
I haven't read any way to calibrate a Mk3 speedo. You only get that with a Mk4.
« Reply #4 on: 07 September 2014, 21:17 »
205/40/17 tyres will keep the gearing / speedo close enough
Offline gazza1602
« Reply #5 on: 07 September 2014, 23:13 »
cheers guys for all your help its been much appreciated. would the tyres at 205/40/17 fit okay on wheels that are 7j wide without too much stretching?
thanks again
Gaz
« Reply #6 on: 08 September 2014, 21:24 »
Yes fine, I ran them on 7.5 rims all ok.
