Author Topic: Jacking points on a mk2  (Read 1851 times)
Offline Gambit
« on: 21 October 2003, 15:20 »
anybody know the definitive guide for jacking the front?!?
i jacked mine under the gearbox with a block on the trolley
i know about the trolley jack points behind each wheel arch
can you use the front cross member also??
golfvr6
Re:Jacking points on a mk2
« Reply #1 on: 21 October 2003, 18:20 »
Don't jack it under the gearbox as you will strain the engine mounts. I usually put the jack under the rear subframe/wishbone mount, or you could put the jack under the subframe, but thats usually where i would put the axle stands.
