Author Topic: DashCommand by Palmer Performance any advice?  (Read 2033 times)
Offline Layfs
« on: 05 September 2014, 17:14 »
I've hooked up the above programme on my iphone using the OBD port.  After going for a blast it is recording at 6116rpm's;
232hp power
208lb-ft torque
14.2psi boost
As far as I am aware my car is a standard 180bhp AUQ engine.
My questions is how accurate are the figures through the OBD2 connection.  If I'm honest it doesn't feel that fast but I'm used to driving chipped diesels which is a completely different power delivery system
Offline GTi_James
Re: DashCommand by Palmer Performance any advice?
« Reply #1 on: 07 September 2014, 13:12 »
If its standard like you say then I'd ask for a refund on the app
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 07 September 2014, 14:31 »
if you're running 14.2psi boost you're running a stage 1 map, not standard. With that boost you won't be hitting 232bhp though
Offline Scott D
« Reply #3 on: 07 September 2014, 14:56 »
Way over those figures for BHP
Can dash command log the mass air flow sensor - reading from that tends to be more accurate for calculating BHP by multiplying g/s reading by 1.25
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Layfs
« Reply #4 on: 08 September 2014, 10:24 »
MAF reading is 19.2 lb/min....
