Author Topic: KO3s  (Read 3354 times)
Offline Dalo Harkin
Re: KO3s
« Reply #10 on: 15 September 2014, 17:42 »
Is there a simple guide to taking off the turbo? or does it all involve draining of oil removing exhaust manifold and that?
Yes you need to drain the oil and coolant, the turbo is mainly supported from the top (through the manifold 3 bolts) and onto the downpipe, you need to remove the coolant and oil lines which is a pita, as is swapping from the top of the car to the bottom all the time.
Offline Chris.
Re: KO3s
« Reply #11 on: 15 September 2014, 18:56 »
Remove boost pipework
Remove manifold
Remove supporting bracket
Remove 4x bolts on downpipe
Remove oil drain from TURBO side
Remove coolant feed from block
Remove oil feed line at turbo banjo
Remove TIP from where rubber meets metal part (if OEM TIP)  Turbo if aftermarket
Lift turbo out the top.
Click For Build Thread
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
Re: KO3s
« Reply #12 on: 15 September 2014, 21:56 »
i really want to attempt this myself but ill most like f**k something up haha
