Author Topic: Pressure testing  (Read 2021 times)
Offline rio_gti
Pressure testing
« on: 02 September 2014, 23:50 »
Hey all!!! (Again!!!)
When doing a pressure test, if I block at the tb and pressurise from just after the turbo, it holds.
But, if I block the tb and pressurise from the tip, I get a gloopy bubbling sound from the back of the engine (sounds like its coming from in the sump  :undecided: )
Is this normal?
Offline Dalo Harkin
Re: Pressure testing
« Reply #1 on: 03 September 2014, 12:38 »
you got a modern pic of the bay?
surely any bubbling would be the pressure making the oil in the sump bubble?
Offline rio_gti
« Reply #2 on: 03 September 2014, 14:44 »
Well that's what I thought but is air meant to get it there via (I think) the turbo?
I'll get some pics soon!!!
Offline Tezmax
« Reply #3 on: 21 September 2014, 17:46 »
Cut my pressure tester down to a reasonable size and plugged into tip and it held preesure until dip stick or oil filler cap was removed then i got the gurggle/bubbling sound. Blew some smoke through the system and came out oil filler cap only. Does this mean i have no vac leaks?
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline rio_gti
« Reply #4 on: 21 September 2014, 21:39 »
You still got the hockey puck etc all connected?
Offline Tezmax
« Reply #5 on: 22 September 2014, 00:09 »
Yep, didn't disconnect anything else. Was hoping to find a leak somewhere but it doesn't appear to have one.  :angry:
Offline rio_gti
« Reply #6 on: 22 September 2014, 08:12 »
Makes sense.... As my breathers are straight to atmosphere that's why my 'bubbling' is straight away, so if I were to block them both it should hold pressure in the block (didn't think this was any good to do  :undecided: )
Did you block the pipework at the tb?
Offline Tezmax
« Reply #7 on: 22 September 2014, 17:42 »
Held pressure under my own breath and it blew back when releasing me gob :sick: Didn't connect my compressor with regulator yet as not totally confident in what i'm doing.
Left tb alone, i guess it would be in the closed position when engine not running but would that be air tight :undecided: I wouldn't of thought so
Finished product:
« Last Edit: 22 September 2014, 18:05 by Tezmax »
