Author Topic: flywheel  (Read 1819 times)
Offline davidgtrr34
flywheel
« on: 02 September 2014, 09:26 »
The dmf is gone and I want to fit a SMF. Do I need to buy a full clutch kit or can I still use the old clutch and pressure plate. The clutch and pressure plate were only done 2000miles ago
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline davidgtrr34
Re: flywheel
« Reply #1 on: 02 September 2014, 12:47 »
Also if I fit an OEM dmf will it last at 320bhp
Offline Dalo Harkin
Re: flywheel
« Reply #2 on: 02 September 2014, 13:04 »
looking at the spec while its out I would just replace the clutch too.
Offline davidgtrr34
Re: flywheel
« Reply #3 on: 02 September 2014, 14:32 »
What would be a good clutch kit that would have everything in it
Offline mcgee9t2
Re: flywheel
« Reply #4 on: 02 September 2014, 18:35 »
sashs clutch and g60 flywheel is the usual upgrate. have a search for it plenty of info, including info on the part numbers for the g60 flywheel and info on the trade system vw have (or had, assume they still do it) where you can buy a cheep flywheel from a scrap yard, take it to vw and trade it in and save some money iirc
Offline rockmonkey69
Re: flywheel
« Reply #5 on: 02 September 2014, 23:51 »
Spec stage 3 here, it bites hard but is useable on the roads, little grabby when trying to park. Think it's the 7kg flywheel I got so it's not too light for road use but you do have to give it a bit more throttle when moving off. The biting point is lower and the pedal stiffer. Good bit of kit and able to handle a healthy amount of power.
