Golf mk4
Wazzzer
is there a simple ko3s hybrid option??
Topic: is there a simple ko3s hybrid option?? (Read 4434 times)
davemk4
27 August 2014, 13:10 »
Im due to remove my k03s turbo to fit new actuator amongst other stuff. Is there anything i can swap the turbo with that doesnt require all injectors etc to be changed. Getting custom map fmic all done same time but thought is there anything i can do to squeeze abit more bhp while doing all this work?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Dalo Harkin
Re: is there a simple ko3s hybrid option??
27 August 2014, 13:18 »
in short no, if you have all the supporting mods go K03s stage 2 and that'll pretty much max your K03s in terms of power. If you do go stage 2 you ideally want a yellow spring in the DV and Actuator
You could add things like WMI (which is next on my to do list
) and then its staying as it is
Last Edit: 27 August 2014, 13:29 by Dalo Harkin
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
davemk4
27 August 2014, 15:03 »
Well im kitting car out with handling mods to cope spax coilovers etc THS intercooler kit. Forge 008 and forge actuator. What about a aftrrmarket manifold? Few gains to be had?
Dalo Harkin
27 August 2014, 17:40 »
THS Intercooler is expensive and when I tried to get one ages ago they were struggling with stock, have a look at the wellycooler, and save yourself a few hundred quid....
nope don't get an aftermarket manifold, just get either yours or another stock one ported and polished
davemk4
27 August 2014, 18:11 »
Ye i know they more than a welly cooler but they such a good fit and real neat too. So if i bought a 2nd hand oem.manifold and got it done ported etc that be a ok?
shaft69
27 August 2014, 18:27 »
Just get bbt k300 and be done with it good for near 300hp with supporting mods ko3 housing to so straight swop.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
davemk4
Reply #6 on:
27 August 2014, 18:52 »
Supporting mods are? Lol
MoMartin
Here all the time
Reply #7 on:
27 August 2014, 20:52 »
Bigger tip, 3" maf housing, induction kit, injectors, fuel pump, and performance exhaust too i would imagine.
rockmonkey69
Reply #8 on:
28 August 2014, 00:38 »
I would advise doing the conrods if you plan to have launch control and flat shifting mapped in. I am also inclined to say water meth too - it serves to help make the power more consistent all year around, even on the hottest days
davemk4
Reply #9 on:
28 August 2014, 05:53 »
So a k300 would run on my current set up along with uprated fuel pump injectors as ive got rest of mods all ready
Golf mk4
Wazzzer
