Golf mk3
hardmonkeys
Correct offset
Topic: Correct offset (Read 2279 times)
Sublimerob
Just got here
Correct offset
23 August 2014, 18:44 »
Got some cades Eros, 15 inch 6.5 offset 35 and the rears fit lovely but the fronts don't as they are hitting the caliper, any advice?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Correct offset
23 August 2014, 20:40 »
what car are you driving? and what brakes?
Screech16v
MK3 20vt AGU
Re: Correct offset
24 August 2014, 16:41 »
You may need to space the wheel slightly due to construction of the actual wheel
tweed
Forum addict
Re: Correct offset
24 August 2014, 22:46 »
Also when measuring for a spacer take into consideration your pad wear. If the are low you may need to add 15mm onto the measurement. If pads are new then only add 2mm.
Google search it. "What spacer for cade eros on mk3 golf gti."
Untitled
by
tweedub
, on Flickr
Sublimerob
Just got here
Re: Correct offset
25 August 2014, 18:47 »
It's a mk3 golf gti with standard brakes. I will have a bit more of a search.
tweed
Forum addict
Re: Correct offset
25 August 2014, 18:50 »
Quote from: Sublimerob on 25 August 2014, 18:47
So what year and engine? There are two types of brakes for these cars. 280mm and 288mm. Obviously the 288mm will be a larger spacer.
Untitled
by
tweedub
, on Flickr
Sublimerob
Just got here
Re: Correct offset
Reply #6 on:
26 August 2014, 20:57 »
It's a 1996 8v.
Golf mk3
hardmonkeys
Correct offset
