Author Topic: Advice on buying  (Read 1466 times)
Offline jpbristol
Advice on buying
« on: 22 August 2014, 16:49 »
Ive seen a 1.8T only 3 miles away from me. Black 3 door which is what I want, 90k miles. Inside is a bit worn but thats not a problem.
Would you guys recommend getting an independent mechanic to view it to make sure i dont buy a duff?? I have no experience/knowledge of what to look for when it comes to used motors.
Offline matty james
Re: Advice on buying
« Reply #1 on: 22 August 2014, 21:51 »
u could but go with a mate take it for a good drive , check oil ,coolant condition -make sure theres no knocks and other noise s while drivin , floor it to make sure its boosting ok. fling it round a corner to make sure traction control is working.make sure it aint puffing smoke from exhaust .take it to a vw specialist and get codes read on it and get a print out if poss. make sure theres no warning lights staying on the dash. use all the gears to make sure there ok .the list of checks goes on . but there the main 1s.theres always an element of luck when tryin to find a good 2nd hand car  :smiley:
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline matty james
« Reply #2 on: 22 August 2014, 21:56 »
also try all the electrical things on it like lights-windows-heaters etc to make sure there working . and have a good look at its history -receipts and mots etc.
Offline Rhyso
« Reply #3 on: 22 August 2014, 22:12 »
Make sure the car is cold and not been run up prior to arrival as that can hide a number of things
When up to temp make sure the gauge sits at 90. It should sit there all day long
Listen out for noises from the rear; they suffer from rear beam bush failure. Knocking from the front will most likely be anti-roll bar bushes
Bounce the suspenion on each corner to ensure the shocks are in good condition. They should settle almost immediately after you have bounced the car
