Author Topic: Start/stop error, VCDS faults, how to clear  (Read 5991 times)
Offline alexbach
« on: 20 August 2014, 19:49 »
Can Anyone helps me to clear this errors?
I have a brand new GOLF GTI MK7.
My start stop is not working, with vcds theses are the errors that appears.
I can hardly believe that a brand new car with less then 1000miles on it has a real problem.
This problems happened right after I installed a RaceChip Ultimate, but they wont go away, I already removed the RaceChip.
PS.: I can not control the Front Assist By the MMI, I can not deactivate the ESC by the MMI even though everything is working fine, I did test all functions driving the car, ABS, ESP and front assist works fine. The only funtion that is not working is the Start-Stop system.
It shows an error on the Car.
There is no fault light on, The only way to know about theses faults is scanning with VCDS.
Thanks much for the help!!!
Offline Gnasher
  • Formerly GnasherVXR
Re: Start/stop error, VCDS faults, how to clear
« Reply #1 on: 21 August 2014, 06:02 »
Hold on - you installed a 'racechip' and then it stopped working and then you say you can't believe the car has a fault with less than 1000 miles on it?
I'd go back to the manufacturers of the racechip and check they tested it on a car with the same features as yours!
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline GrahamFR
« Reply #2 on: 21 August 2014, 07:23 »
im assuming you have cleared all these errors and they still come back? It sounds like your racechip has annoyed your ecu, if clearing the faults doesnt help, try disconnecting the battery for a 5mins and seeing if it all resets.
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline alexbach
« Reply #3 on: 21 August 2014, 13:13 »
I did try to clear them using the VCDS but no success. I brought it to a dealer he disconnected the battery for couple minutes qnd put it back, but the errors stayed there, he sayd he would need to send the report to the manufecture and work with them online.
I got in touch with the RaceChip personnel and they as for some pictures of the racechip installed, send it to them, they said it looks alright. They are waiting on what the car manufeture will say.
Im going to try to disconnect the battery myself and see if I get different results.
Thanks guys. Please keep sending me more ideas if you have.
Offline alexbach
« Reply #4 on: 21 August 2014, 15:48 »
I tried the battery deal, disconnected it and left of for an hour, the faults still there, cleared the new faults that appeared but the old ones remains there.
any other suggestion?
thanks
Offline ajmoir36
« Reply #5 on: 21 August 2014, 17:57 »
I would suggest going back to where the race chip was plugged in, and removing/re-seating the connector. Checking no pins are pushed back in the connector.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline alexbach
« Reply #6 on: 21 August 2014, 18:27 »
Good call. I did check if it is seated properly but haven't checked if the pin are still in the right place.
Do you think is there a chance that the RaceChip installation could have f**ked up my sensors?
Offline GrahamFR
« Reply #7 on: 21 August 2014, 19:14 »
Yes lol but it could be coincidence
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline ajmoir36
« Reply #8 on: 21 August 2014, 19:19 »
I doubt it could of knackered the sensors, it looks more like a bad connection.
