Golf mk4
Wazzzer
Stall after cold start
Topic: Stall after cold start (Read 1506 times)
jamiesgolf
20 August 2014, 14:29 »
Hi guys, i have a 2.0l 8v GTi. when I cold start the car it starts up fine but as the revs come back down it will just stall. It's only on a cold start and the second I rev it slightly it will be ok. I cleaned out the throttle body yesterday - which was filthy, but that hasn't changed anything. Any ideas what else it might be?
Thanks in advance
MoMartin
Here all the time
Re: Stall after cold start
20 August 2014, 16:16 »
Try Resetting all codes via vag com, my car once had the same problem with stalling, and cleaning the throttle body didn't make a difference, but once I reset all the codes too, it ran sweet as a nut
Dalo Harkin
21 August 2014, 08:28 »
if you do reset the codes make a note of them first, and then check a day later to see what has come back
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
