Author Topic: GTI my15 - usb compatible?  (Read 2215 times)
Offline scoobyc
« on: 19 August 2014, 21:58 »
Quick query, I've read the manual and it says it basically depends on which market the car is in but it might have a USB connection for reading a memory stick! Can someone tell me if it has a connector as standard or is it a case of buying a lead for the connector in front of the gear lever? I don't have sat nav if that makes any difference. Thanks.
Offline Jimble
  • Moderator
Re: GTI my15 - usb compatible?
« Reply #1 on: 19 August 2014, 22:24 »
If you opt for the pro nav then there is a usb connection in the cubby, any other head unit comes with VW's "media-in" connection which requires a usb cable adapter, although you'd be just as well using an SD card in the glovebox slot which is standard on them all.
Offline scoobyc
« Reply #2 on: 19 August 2014, 22:26 »
Perfect thanks, I'll order an sd card then.
Offline Jimble
  • Moderator
« Reply #3 on: 19 August 2014, 22:28 »
:afro:
