Author Topic: dog bone mounting bolts  (Read 1802 times)
Offline gamestaffords
« on: 19 August 2014, 08:16 »
Hi, i read some wear you need to replace the bolts when replacing the dog bone? is this correct? and if so where can i get the bolts from? any part numbers?
Thanks
Offline Quackers
Re: dog bone mounting bolts
« Reply #1 on: 19 August 2014, 09:51 »
Correct. Stretch bolts - shouldn't be reused. You can get them from VW. Theres only four bolts so shouldn't break the bank.
« Reply #2 on: 19 August 2014, 10:01 »
Thanks
Offline SI74
« Reply #3 on: 19 August 2014, 11:41 »
I have them in a bag in the garage waiting to go on. If you don't have the part numbers by tonight I'll post them up.
Offline mcgee9t2
« Reply #4 on: 19 August 2014, 12:40 »
2 x N10268302 bolt  £1.09 each, £2.18 total
1 x N90597005 bolt  £0.84
1 x N10246603 bolt  £1.05
i believe
prices may be slightly out.
taken from this thread
http://www.golfgtiforum.co.uk/index.php?topic=89174.0
however just go into vw and ask for the bolts needed to change the rear gear box mount and they will know which ones
Offline brewey
« Reply #5 on: 19 August 2014, 16:29 »
If you can't for what ever reason get to VW then Psi tuning also sell them, but they possibly cost a bit more. When I polybushed mine I bought the ECS kit from awesome that had both bushes and the bolts saved myself some money over the powerflex option.
2000 1.8T ARZ - OEM+
Offline SI74
« Reply #6 on: 19 August 2014, 18:18 »
Part numbers I have from the wee bags they came in are
N 106 535 03
N 905 970 05
N 102 683 04  x2
