Author Topic: HELPPPP!!  (Read 5745 times)
Offline AlexEDITION30
Re: HELPPPP!!
« Reply #10 on: 21 August 2014, 18:49 »
Engine temp sensors my next move i reckon, if thats not it then its going to have to go to VW an have a look at that Water Pump, an yeah its got warrenty so if the pumps faulty they will cover the parts an labour costs,
So do you guys not think theres any connection with it being ran low on oil an now overheating?
Cheers guys :)
Re: HELPPPP!!
« Reply #11 on: 25 August 2014, 21:29 »
Maybe, you could have damaged the engine.
Offline th3_f15t
Re: HELPPPP!!
« Reply #12 on: 29 August 2014, 23:17 »
How long was it run on low oil? The 2.0 TFSI engine needs good oil and plenty of it all the time.
Moving over to Flickr, sorry for the broken picture links!
Re: HELPPPP!!
« Reply #13 on: 30 August 2014, 08:14 »
I think it is damage to the engine but its very strange how everything still works fine? I have been giving it some pedal often an theres no loss of power
Very very strange
Re: HELPPPP!!
« Reply #14 on: 30 August 2014, 08:16 »
The Oil light came on and i drove about 2-3 mile to the nearest garage to buy some an filled it up there, so not long really, but im no mechanic haha
Offline Screech16v
  • MK3 20vt AGU
Re: HELPPPP!!
« Reply #15 on: 31 August 2014, 13:58 »
Was the warning light a level or pressure indication
Offline Bandit127
Re: HELPPPP!!
« Reply #16 on: 31 August 2014, 16:50 »
I once refurbished the crank on a Cortina for the sake of a faulty oil pressure switch.
If you can, I would get the gauge checked with VCDS before paying out the labour for a new pump to be fitted.
And don't take long with it. The headgasket will not like the additional expansion and contraction it is suffering from not running at a stable temp.
Re: HELPPPP!!
« Reply #17 on: 03 September 2014, 15:29 »
Im not sure it was just an icon of an old oil boat, like a gravy boat ha,
And how would i go about getting the VCDS checked mate? Do local garages do it? I know its need sorting asap before the head gasket starts to give up :/
Thanks guys :)
Offline Bandit127
Re: HELPPPP!!
« Reply #18 on: 06 September 2014, 19:18 »
There are two temp sensors. You can compare one to the other with VCDS.
It will cost you £20 or so to get it read . Ask on this forum if there are any members that would do it for you.
Offline mk5GTIDSG
Re: HELPPPP!!
« Reply #19 on: 18 September 2014, 15:36 »
Any updates here mate? Hopefully the overheating issue has now been resolved!!
