Author Topic: New clutch and flywheel  (Read 3462 times)
Offline seanbmx
« on: 17 August 2014, 20:17 »
So I've just recently found out that my clutch is slipping. I'm going to be replacing both the clutch and flywheel, I thought about using the g60 flywheel with Sachs clutch kit but iv heard mixed reviews about it.
What do you guys think about these pieces of kit?
Offline spikenipple
Re: New clutch and flywheel
« Reply #1 on: 18 August 2014, 12:25 »
Which car?
Offline seanbmx
« Reply #2 on: 18 August 2014, 21:59 »
1.8t agu golf
Offline MoMartin
« Reply #3 on: 19 August 2014, 14:58 »
I've done the vr6 / g60 upgrade and i definitely recommend it. it costs about the same as replacing the stock clutch, and on top of that it can handle up to around 300 bhp / 300 ft lb of torque and you also get a really light clutch.
Offline Dalo Harkin
« Reply #4 on: 20 August 2014, 12:41 »
Another positive here for the G60 and sachs clutch kit  :wink:
I bought the G60 flywheel from VW (without exchange) and bought the clutch kit as it worked out cheaper, this was a while ago though so scene tax may have been added
Offline MoMartin
« Reply #5 on: 20 August 2014, 12:51 »
Thought I should add that I bought the whole kit (flywheel and sachs clutch) from techniclutch on ebay for £165, mine turned out to be fine, but a fair few others have had a lot of bad reports from them.
Offline Dalo Harkin
« Reply #6 on: 21 August 2014, 08:33 »
I'm pretty sure that's come down quite a bit (alarm bells ringing) I think the clutch kit alone used to be near that and then I got the flywheel from VW for around £50, the set used to be around £230-£250 from memory, I only remember because VW wanted an absolute fortune for a dual mass setup and when mine went I thought fook that
Offline seanbmx
« Reply #7 on: 23 August 2014, 18:21 »
Yeah I've heard a few bad reviews but the good reviews seem to outweigh the bad. That's the seller I was looking as we'll, not a bad price for the kit
Offline andy68
« Reply #8 on: 24 August 2014, 13:18 »
I've got the 14lb ECS kit, well impressed with it, not the cheapest option though. Try TPS if there one near you and pricing is similar to the techniclutch kit from what I remember
Offline seanbmx
« Reply #9 on: 27 August 2014, 20:02 »
Sorry to sound stupid but when you say TPS do you mean trade pat specialist?
