Golf mk4
Wazzzer
Code help
Topic: Code help (Read 1751 times)
GTi_James
Code help
16 August 2014, 09:55 »
i need some help with these please
17705 - VAC leak i know
17545
17522
16514
can anyone give the cause and cure?
thanks!
Nino
Re: Code help
17 August 2014, 13:58 »
Alright mate, could be a number of things, but suggests your system is running too rich.
When my 1.8t was doing this I found that bypassing the N249, cleaning the TB, cleaning the MAF and simplyfying my PCV system fixed all of this.
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
GTi_James
Re: Code help
17 August 2014, 16:41 »
Cheers bud, got the parts sorted, just need to fit now, taking out the SAI as well
Nino
Re: Code help
17 August 2014, 17:47 »
Dont forget if you delete the sai get the resistor to prevent error code.
VW Car history
Current
Dalo Harkin
Re: Code help
18 August 2014, 13:12 »
just get 3 resistors and delete the SAI, N249 and N112, you could also do the carbon canister too at the same time, so if you want that too, you'll need 4 resistors
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
Code help
