Author Topic: 2.0 GTi bad MPG  (Read 2275 times)
Offline Blazeman1995
2.0 GTi bad MPG
« on: 15 August 2014, 18:04 »
I put around 10 litres of petrol in and have only travelled about 6 miles. Baring in mind it is idling at about 1000rpm. And I was only going to third gear. I have no idea as to what the problem is. So does anyone know what might be the problem and how much it will cost to fix?
« Last Edit: 15 August 2014, 18:18 by Blazeman1995 »
Offline itavaltalainen
Re: 2.0 GTi bad MPG
« Reply #1 on: 15 August 2014, 18:32 »
what's the engine code?
10 litres and 6 miles.... my guess would be a fuel leak... but then again the tank gauge is hardly a precision instrument, especially when near empty.
for idle issue engine code would be a bit more crucial
VW BUSH
Re: 2.0 GTi bad MPG
« Reply #2 on: 15 August 2014, 19:16 »
It would be running absolutely awful if that was the case.
It's a leak or as our Austrian/Finish friend I forget which says, dodgy gauge giving you a bum steer.
Re: 2.0 GTi bad MPG
« Reply #3 on: 15 August 2014, 19:22 »
I was told by a specialist that the engine problem was the sensor on the throttle body. I've had a brief check for a leak and there doesn't appear to be one. And there is no fuel on the floor beneath the car.
Offline boneybradley
  • Back in a Mk3...
Re: 2.0 GTi bad MPG
« Reply #4 on: 15 August 2014, 19:27 »
If it was a dodgy throttle body sensor, you would smell the fuel out the exhaust as the engine would add more fuel thinking it needs it due to the throttle position (b.t.w it will kill the catalyst)
I have a good throttle body (used) available and it's a 5 minute job to swap.
Re: 2.0 GTi bad MPG
« Reply #5 on: 15 August 2014, 21:56 »
It doesn't have a smell of petrol out the exhaust. And I have just drove it another 20 miles and the fuel gauge is showing fuel. So I think the sender unit might be dodgy. I still think the throttle position sensor might be at fault as it used to cut out on start up but as soon as I ajusted the throttle cable it doesn't do it as much. This is the cause of the high idle but I need to figure out why it cuts out.
Offline Therusterman
Re: 2.0 GTi bad MPG
« Reply #6 on: 16 August 2014, 14:14 »
Have you had a diagnostics done to see if any fault codes are thrown?
Offline snozan
Re: 2.0 GTi bad MPG
« Reply #7 on: 16 August 2014, 15:18 »
Don't you have MFA? i know its far from precise, but pretty close (at least mine). All is depending how you drive. And never trust your fuel gauge.
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
