Author Topic: coilover/suspension kit question  (Read 4289 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Re: coilover/suspension kit question
« Reply #10 on: 03 September 2014, 18:49 »
personally i wouldnt buy any other than jom coilovers now having used them, well decent for the money
Offline davemk4
« Reply #11 on: 03 September 2014, 19:28 »
Im after something far better in quality and ride comfot. I know alot use joms/fk all same any way but want something with a good name behind for build and ride performance.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline damien010685
« Reply #12 on: 04 September 2014, 00:33 »
They are cheap lows and that is the only reason anyone likes them if you stuck a decent set on you would see the difference night and day!! joms are great for people who want cheap lows and don't mind having a harsh ride!
Offline davemk4
« Reply #13 on: 04 September 2014, 06:32 »
Exactly. But getting annoying now. Too much choice. Got apex coil over 450, avo at 660. H&r 725.00 and the kw etc around 750. Come on which one best lol. Npt doing track just want a firmer more sportier ride 40-45mm drop.
Will my arb rub on oem 16" wheels when dropped 40-45?
Offline shaft69
« Reply #14 on: 07 September 2014, 19:57 »
Ive ran spax adjustables on my previous mk2 and 3 brilliant wouldnt hesitate use them again. The softest ride is harsh but i like it like that, feel more like track suspension than for road. i have H&R coilovers now on they mk4 nowhere near as harsh but cost a lot more than my spax did.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott D
« Reply #15 on: 07 September 2014, 23:10 »
I've got AP coilovers on as came with the car when bought it.
It is probably down by 60/70mm at the moment and only just slightly harsher than when had a 40mm Weitec shocks & springs kit on my old MK4.
A lot less body roll even without a rear arb compared to previous car although can be a bit bouncy when going fast on rough roads.
They are mid budget think £400 new and I bet with a sensible drop would be more than usable day to day.
Front ARB will be fine with a 40-45mm drop
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline davemk4
« Reply #16 on: 08 September 2014, 05:14 »
Well i took dpm performances geeat advice. Ordered stainless steel kw veriant 1 coilovers due any time this week
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #17 on: 08 September 2014, 10:02 »
I have the same requirements for my own mk4 albeit an estate.  Do the rears vary on mk4's like the mk3's do or can I use normal hatchback suspension kits?
Am I right in thinking a spring and strut set up will just have higher spring rates to compensate for the rear load...and coilovers would just be a case of adjusting accordingly?
