Author Topic: Car DeLocked & Battery Dead Help!  (Read 3847 times)
Offline dom
  • Back in a Mk4
Re: Car DeLocked & Battery Dead Help!
« Reply #10 on: 15 August 2014, 23:25 »
Have you upgraded your headunit to an rcd/rns500?
Offline fazsnatch
« Reply #11 on: 16 August 2014, 12:56 »
No i have not changed anything on it, I still got the default mk5 golf head unit.
I am just wondering how would you know if the alternator went, that could be a possibility. As the car batterry does fill up takes a while. Then you can drive the car, but if you turn it of and leave it for 2 minutes then the battery is dead again.
Wouldnt think its a bad battery but may have to test that too.
Offline matty james
« Reply #12 on: 16 August 2014, 21:38 »
your battery should be holding around 12.6v more or less. bring the revs up to 2000rpm ish and hold for a couple of mins .you should know be seeing your battery voltage rising upto 14 volts ish .this means your altenator is working and chargin your battery.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline Dipesh2031
  • Options bae?
« Reply #13 on: 20 August 2014, 00:09 »
check the battery terminals are bolted down tight, my car was dying before and I had a new battery!
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
Offline Cerialkarpins
« Reply #14 on: 20 August 2014, 18:48 »
going back to the no keyhole to get in manually, is there not a little bit on one of the door handles where u can pop the key into (usually on the underside) and pop off a plastic cap which exposes the manual keyhole? sorry im late with this. mine has an exposed keyhole so i cant see.
