Author Topic: Rear half creaking like mad - Where is it coming from?  (Read 8515 times)
Offline Booth11
Re: Rear half creaking like mad - Where is it coming from?
« Reply #10 on: 14 August 2014, 15:49 »
Have you tried it with parcel shelf out?  I expect you have, but I remember someone previously saying that some mk6s got noise associated with the rubber stoppers on the ends of cord holding the shelf.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline RocketRossUK
« Reply #11 on: 14 August 2014, 16:33 »
Yeah i have nothing in the rear at the min, no seats, no shelf's, no carpet, no spare wheel....and still its there...
Offline Dipesh2031
  • Options bae?
« Reply #12 on: 16 August 2014, 16:29 »
did you sort it out in the end?
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
« Reply #13 on: 16 August 2014, 19:00 »
No not really, I dropped my ARB down from track to sport and its still a bit creaky. Im thinking about removing my boot lid, re-greasing and re-fitting to see if that makes any difference, as it only does it when the bootlid is shut.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #14 on: 16 August 2014, 23:34 »
White spray grease the hinged and also the strut hinges. But more likley the rubber mine regular needs extra loob to stop it creaking. The rubbers on the wires to the boot often need loobjng too!
Current Garage:
35+ years of GTI ownership.
Offline Booth11
« Reply #15 on: 16 August 2014, 23:48 »
If it is the boot door seals/rubbers then as stated previously, Krytox works wonders.  I used it on my front door seals and it completely eliminated the noise problem I was having (was recommended to me by Beddie and GS Wax).  Did the rest of the car with it just for good measure.  Not cheap for a small bottle but worth it.
Available from TPS, part no. G052172A1  VW Krytox  (DuPont GPL-105).  30ml £28 plus VAT
« Last Edit: 16 August 2014, 23:52 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
« Reply #16 on: 18 August 2014, 08:59 »
Not sure which bits you mean, can you takes pics of where you think i should lube. What lube do you use on the hinges? Ive only used WD40 so far. Thanks
« Reply #17 on: 19 August 2014, 09:18 »
^^^^ @ Snoopy - Any ideas?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #18 on: 19 August 2014, 17:49 »
I used
ixtar white spray lithium grease. On the boot hinges at the top of the hatch.
Also on the ball/sockets of the struts on the sides of the hatch.
Autoglym rubbercare on the rubber boots covering the wiring to the hatch.
krytox on the rubber seal.
Current Garage:
« Reply #19 on: 21 August 2014, 16:43 »
I used
Sprayed the hinges on top of the hatch, sprayed the seals. Still the same.
Do anyone know what size sockets fits the bolts on the hinges? Its not a standard size  :sad:
I was thinking about remove the bootlid and re-fitting.
