Author Topic: brake pads front  (Read 1995 times)
Offline viperjsy
brake pads front
« on: 12 August 2014, 23:21 »
hi I have a agu gti 1.8t golf 1999 don't think it has a wear indicator the pads I just got has got a wire do I just cut it off and it will be ok thank you
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: brake pads front
« Reply #1 on: 13 August 2014, 12:09 »
You'll have a wear indicator built in but you don't have to use it. You can either code it out in VAG COM or bridge the terminals so the light goes out
I've only just seen your PM too, I'll reply in a mo
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 13 August 2014, 12:28 »
up to 00 they didn't have wear indicators but use an identical size/shape pad, Just chop the wire off and all will be good.
Offline viperjsy
« Reply #3 on: 13 August 2014, 18:45 »
thank you
Offline gm8
« Reply #4 on: 13 August 2014, 18:54 »
mine is a 99 agu , and I do have wear indicators.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 13 August 2014, 19:29 »
same here
  • Back in a Mk3...
« Reply #6 on: 13 August 2014, 20:33 »
same here
doesn't surprise me, VW list them as up to 99 without and 00 onwards with (I guess they changed for model year 00, so mid 99 really?)
