Author Topic: Fuse alternator issue  (Read 1727 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
« on: 12 August 2014, 19:37 »
My car yesterday hesitated starting a few times and started lighting up abs,traction control and airbag in the morning and afterwork yesturday few miles from my house went limp mode, id took a stab in the dark and thought id killed the battery due to having installed a sub.
Today it started fine in the morning but died when i got to work, I noticed the Fuse is melted ontop the battery the terminal to the far left so i was looking at the alternator but its brand new  bought a new fuse box and all the bits 70 odd quid is this likely to fix the problem because i dont actually know why it melted
The car now runs fine now and charges battery again?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuse alternator issue
« Reply #1 on: 13 August 2014, 12:11 »
If my memory serves me correctly this is the cable coming from the alternator to the battery breaking down, very common
  • Mk4 1.8t AUM
« Reply #2 on: 13 August 2014, 22:29 »
ah i see is it easy to replace do you know im struggling to find any information on it, and according to tps the cable is 45 quid ! Bit steep
Offline shaft69
« Reply #3 on: 14 August 2014, 07:00 »
I had to replace alt, line and fuse box.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline matty james
« Reply #4 on: 14 August 2014, 21:29 »
as wazzer said -either poorly fitted cable or cable knackered .
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
