It does if there is fook all left on the friction plate, as all you will be running on is bare metal in the clutch housing. HEnce they will be burning when spinning and as all golf clutches on mk2s are dry clutches then they run the risk of welding together.
Get it done as soon as, might i suggest getting a sachs sports clutch aswell, they are a bit more hardy and will give you a nicer bite when they go engage.
