Author Topic: golf mk1v APR remap info etc  (Read 1769 times)
Offline donno
« on: 09 August 2014, 14:04 »
Hi All ,
Quick question anyone on here had an APR remap on their AUM.Once my car is ready/fixed and healthy , I am going to remap it.So suggestions please.
Thanks very much in advance
Cheers Donno.
Offline shaft69
Re: golf mk1v APR remap info etc
« Reply #1 on: 09 August 2014, 14:18 »
I ran APR on my last mk4 with aum engine stage 2 with all ems files, briiliant map couldn't fault it 221hp/250ish tq. There pretty expensive but sale on now i think rate it highly. R-tech is cheaper and are as good, can't say better as never driven them back to back but APR was spot on.
« Last Edit: 09 August 2014, 14:20 by shaft69 »
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline donno
« Reply #2 on: 09 August 2014, 16:54 »
Hi Shaft69 ,
Thanks for the reply ,Soon as my car is healthy I will pop into Tuningwerkes and get the remap done.
Cheers Donno
Offline shaft69
« Reply #3 on: 09 August 2014, 18:00 »
No probs mate.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Online barrym381
« Reply #4 on: 09 August 2014, 19:14 »
forget the apr map head straight to r-tech  :smiley:
Offline shaft69
« Reply #5 on: 10 August 2014, 22:09 »
User pref really have had both r-tech and APR both good but found APR more aggressive map which I pref. when my new engine in being mapped by badger5 or R-tech.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott D
« Reply #6 on: 10 August 2014, 22:42 »
I have APR Stage I on at the moment and it's not a bad map makes decent enough power for a near standard car however I would still recommend R-Tech as the linear throttle map makes a massive difference and have no doubts they'd get the most out of it.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
