Author Topic: That Blinking Red Temp light thing......  (Read 2698 times)
Offline Tomonator1985
  • Low 'n' Slow
« on: 09 August 2014, 10:45 »
Hi,
I can find loads of threads on basically "how to ignore the red flashing temp light" BUT i wanted to check what is realllllly means apart from high temp before i ignore it or change the sensor.
Light flashes from start up so it can;t be heat related.
Anything else it could be?
Cheers already:)
*MK2 Golf GTI 16v Small Bumper*
Offline itavaltalainen
Re: That Blinking Red Temp light thing......
« Reply #1 on: 09 August 2014, 11:18 »
talking about a mk2 are we?
could be low coolant warning (or faulty/dirty electrodes in the expansion tank), not sure the mk2 had that already, my mk3 certainly did.
could be faulty temp sender but you can check that with a multimeter easily. i posted a guide in mk3 section few times, the temp/resistance curve on a mk2 is pretty similar but you may still have two separate senders depending on engine
  • Low 'n' Slow
« Reply #2 on: 09 August 2014, 11:26 »
coolant is fine. may just give it a good clean then see how it is. then fork out the mighty £4 for a new sensor!
cheers!
Offline MarcIV
  • Mk4 GTI
« Reply #3 on: 14 December 2014, 22:03 »
I have this on my mk4 on start up, I just assumed it was telling me my engine is cold. :laugh:
Flash Red Mk4 golf 1.8t GTI :)
