Author Topic: Odd sized drive shaft?  (Read 1043 times)
Offline pipworks
« on: 10 September 2005, 12:49 »
Hi,
My inner CV joint on the passengers side gave up on Thursday and left half it's parts along the road. :sad:
Anyway, got it home and all the broken bits left on, off, and got a new CV and boot kit.
But, the boot kit, even though I've checked several manufacturers books, all state the drive shaft is 22mm. :huh:
The boot that came off mine is about 30mm, and the drive shaft doesn't taper at all, it's about 30mm the entire length.
Is this some after market drive shaft I've got or is this normal?
It's a 1990 8v GTi
Thanks for any light you can shed on this.
Offline CARPY25
  • Corrado 16v
Re: Odd sized drive shaft?
« Reply #1 on: 10 September 2005, 14:04 »
etka list two sizes of boots and drive shafts
mosts are listed as 90mm but the 16v is listed as 100mm (would think the g60 is 100 mm as well )
would think the sizes correspond to the wider side of the cv boot 10mm there would be 8mm or so on the shaft
if a were you i would try a 16v cv joint
just a idea does your car have 256mm front disks? if so maybe someone's fitted 16v disks, hubs etc that may need 16v shafts if so they changed your gearbox flanges to take the  bigger drive shafts
Hope this helps
Rob :smiley:
Offline pipworks
« Reply #2 on: 11 September 2005, 09:38 »
I'll try that thanks.
The car is standard apart from the suspension, as far as I know, but as long as it gets it back on the road,
Offline silkyballs
  • more tea vicker??
« Reply #3 on: 11 September 2005, 23:35 »
when i got my new gera box for mine i hade to change the cups on my shafts cos they were different size,they were bigger aswell.easy job though !
http://[img]
