Author Topic: best diverter valve for r-tech stage 1 remap?  (Read 5068 times)
Offline markos
  • kämpfen und siegen
« on: 03 August 2014, 21:47 »
i had the dv changed when i got my stage 1 remap done at r-tech, i think it was just the latest stock part from VW. just wondered if there were any decent upgraded diverter valves out there? and would it make much of a difference between that and the stock VW part?
Offline barrym381
Re: best diverter valve for r-tech stage 1 remap?
« Reply #1 on: 03 August 2014, 21:54 »
if r-tech fitted it then stick with it  :wink:
Offline Poached
« Reply #2 on: 03 August 2014, 22:22 »
Most likely a G revision which is normally adequate.
Many advocate the G revision which has a rubber diaphragm which is supposed to be less prone to splitting and creating a leak than older versions. Guess what, I split a G revision so went back to the D revision which doesn't have a rubber diaphragm. Rolling road results haven't highlighted much of a difference (different days though) and it didn't throw a P0299 code either when scanned despite being split.
GFB do a DV+ product, have a read of this thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,70779.150.html
Offline J400uk
« Reply #3 on: 04 August 2014, 21:33 »
Rev G is cheap and does the job. You just need to treat them as a consumable part (like tyres, brakes or the cambelt) and assume it will probably split at some point and need replacing  :smiley:
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
Offline markos
« Reply #4 on: 04 August 2014, 23:31 »
fair enough... they certainly know their stuff! i'll stick with what i've got for now (until it splits!)
Offline th3_f15t
« Reply #5 on: 05 August 2014, 23:45 »
I run the GFB DV+, which feels great and should last a lifetime. Other options include a Forge unit but these require servicing I believe.
Stick with OEM parts unless you're thinking of serious power. The stock parts are more than up to the job of stage 2+.
Moving over to Flickr, sorry for the broken picture links!
