Author Topic: 2.0 over heating g  (Read 1723 times)
Offline bigginge
2.0 over heating g
« on: 01 August 2014, 22:26 »
Right over heating and no rad fans or air con,
SSo I've bridged fan Switch and they work hanged temp sender no difference, changed fcm for known good one and no change
WWhen over heating with blowers on hot and full blast it's blowing cold, rad top n bottom hose are hot so that rules out thermo stat and the leak off at the header tank has no coolant flowing through it so am I right in thinking the water pump impeller is U/S as coolant isn't flowing this intern means the rad isn't hot enough for the fans to kick in, witch in turn means the air con won't kick in, I've also checked all the fuses and the fuse box on top of the battery,
Any help would be appreciated
