Author Topic: MK2 8v Hydraulic Tappetts  (Read 3668 times)
Offline kevbro1960
« on: 29 July 2014, 23:08 »
Tappetts a little noisey on start up, changed the oil which helped, are replacement tappetts easy to source? Seen them on Fleabay but wondering around quality?
« Last Edit: 29 July 2014, 23:38 by kevbro1960 »
Offline sparkplug
Re: MK2 8v Hydraulic Tappetts
« Reply #1 on: 01 August 2014, 03:01 »
got some for mine from GSF , had the same problem & it cured it  :grin:
1986 GTI atlas grey
roberto
« Reply #2 on: 01 August 2014, 20:47 »
drain 1 litre of oil out of your engine and replace with a litre of atf. run car around gently for 3/4 hundred miles and then change oil and filter. the atf is like a detergent which cleans the muck out off the tappets.
« Reply #3 on: 03 August 2014, 21:23 »
I would also consider dropping your sump and making sure the oil pump pick up is clean.
Offline kevbro1960
« Reply #4 on: 07 August 2014, 03:47 »
Thanks for the info will certainly look into some of the ideas.
roberto
« Reply #5 on: 16 August 2014, 00:39 »
recently stripped down my tappets to there smallest components and cleaned them out with diesel and a scotchbrite and air line. absolutely delighted with the result :smiley: no ticking noises whatsoever now when its cold or hot.
Offline Pwardy
« Reply #6 on: 18 August 2014, 20:08 »
Had the same problem myself; bought a set at reasonable price from ECP and problem solved.  A few miles later as bad as before; I think that is just the way they are?
I take it easy until the engine warms up and then...
Offline Mr Blue
« Reply #7 on: 18 August 2014, 22:44 »
How much were they?
Offline Pwardy
« Reply #8 on: 28 August 2014, 17:19 »
How much were they?
I can't remember, I bought one from VW at a silly price then discovered the exact same item at ECP for much less and so bought another seven.
ECP currently lists:
Aftermarket tappet 311440021 £5.41
Ina tappet 313440020 £16.25
Offline Mr Blue
« Reply #9 on: 30 August 2014, 19:15 »
How much were they?
Top man.
