Author Topic: Hunting on idol *vid*  (Read 3459 times)
Offline rio_gti
« on: 28 July 2014, 00:05 »
Anyone know why it hunts like this on idol?
http://youtu.be/ia0XXkGnsg0
Offline MoMartin
Re: Hunting on idol *vid*
« Reply #1 on: 28 July 2014, 00:37 »
mine used to do that, and it turned out to be a dirty throttle body, so you could try that
also you could try cleaning your iat sensor too, as both of these cause a lumpy idle.
you normally need to reset the throttle body using vagcom after, if you do clean the throttle body that is
« Last Edit: 28 July 2014, 00:40 by MoMartin »
Offline rio_gti
« Reply #2 on: 28 July 2014, 08:27 »
Good suggestions but I cleaned the TB and realigned it befor the remap (was ment to say it's just been mapped)
And what's a iat sensor?!!!
Cheers!!
Offline brewey
« Reply #3 on: 28 July 2014, 08:44 »
I think the IAT is sensor just after TB and is bolted in with a hex bolt.
2000 1.8T ARZ - OEM+
Offline rio_gti
« Reply #4 on: 28 July 2014, 08:45 »
the one that reads the temp in the mani?
Offline brewey
« Reply #5 on: 28 July 2014, 09:36 »
Yeah that's the one. It builds up with all the crap that coats the TB. Worth a go at least anyway. Is you MAF alright?
Offline rio_gti
« Reply #6 on: 28 July 2014, 13:02 »
well tbh when I cleaned the tb I also cleaned this sensor and the inside of the mani so it was nice and clean..... ill try the other sensor I got tonight thou....
maf should be alright as its the one they used on it when they mapped it so they should have picked it up if it was faulty
Offline MoMartin
« Reply #7 on: 28 July 2014, 15:26 »
Maybe a vacuum leak somewhere? though, they normally check for them prior to remapping
Offline dom
  • Back in a Mk4
« Reply #8 on: 28 July 2014, 20:00 »
I'd also suggest a minor vac leak
Offline rio_gti
« Reply #9 on: 28 July 2014, 21:55 »
Looks like I'm gonna have to DIY smoke test/ pressure test then!!!!
