Author Topic: Window problem!  (Read 1978 times)
Offline golf turbo47
  • PURE BOOST!!!
Window problem!
« on: 26 July 2014, 09:06 »
Hello all. So my passenger front window has decided to stay down on this hot heat wave lol. The question I got is the plastic clips are broken can I replace them with the later metal ones or do I have to get the original plastic ones? Cheers.
Silver 2001 1.8T AUM. Revo remap. hybrid K03s.  jetex filter. forge 007p. decat pipe. custom exhaust. anni front valence. rear 4mo valence. anthracite montreal 2 alloys. To be continued....... TIP, H&R suspension,Black 19" RS4 alloys, Carbon fibre wrap roof. anni rear valence, Almost there.....
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Re: Window problem!
« Reply #1 on: 26 July 2014, 19:05 »
VW supply the metal ones Id go for them
Offline mcgee9t2
Re: Window problem!
« Reply #2 on: 27 July 2014, 04:27 »
Vw no longer do the plastic ones. They only do the metal ones. However to buy them you have to buy a window repair kit which includes many parts. IMO buy metal clips off ebay for a few quid. Or even plastic ones they will last a good few years.
Offline daz veedub
  • Operation 1.8t bolf
Re: Window problem!
« Reply #3 on: 27 July 2014, 23:02 »
I just replaced mine with metal clips of ebay, all good , make sure u check which side u order when u do i.e passenger/drivers side
« Last Edit: 27 July 2014, 23:05 by daz veedub »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Window problem!
« Reply #4 on: 28 July 2014, 18:41 »
I don't think VW supply metal ones now, they're made of a different type of plastic so not as prone to breaking (same as the water pumps)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Window problem!
« Reply #5 on: 30 July 2014, 09:01 »
I had this problem and was going to replace the clips but once I took the door card off and got in I found the cable was mangled so needed the whole kit :sad:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
