Author Topic: knock knock, whos there?  (Read 2573 times)
Offline sharki786
  • GOT BOOST??
« on: 24 July 2014, 08:20 »
Front end is making a racket. Basically as im driving the driver side is knocking. It was originaly the pas side but now its the drivers side. On a straight line the knock is rediculous. The wishbones have been poly bushed. I replaced the top mounts about a year ago with febi. But still there. Anyone shed any light?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline snozan
Re: knock knock, whos there?
« Reply #1 on: 24 July 2014, 09:33 »
Gearbox mount. Thats all i can guess on in english. Have some more things, but i dunno what they are called or how to explain them in english  :sad:
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 24 July 2014, 10:13 »
Gb mount is on passangers side. It sounds like the wishbone. Need to check it again. Last time i checked i couldnt tell what it was
*****MK4 GTI T*****
Offline Foreveryoungaus16v
« Reply #3 on: 24 July 2014, 10:41 »
Maybe wheel bearing need replacing
163 BHP (TSR POWER RUN)
Offline tweed
« Reply #4 on: 24 July 2014, 11:39 »
Have you checked for any loose bolts?
Best thing to do is jack the front up and check for movement.
Offline xAntiVenxm
« Reply #5 on: 24 July 2014, 22:42 »
second for jacking it up and checking everything.
grab your tyre, try to rock it back to front then up and down. then try twisting side to side then twist up and down.
then rotate the wheel forwards and backwards.
I had a horrible knock on my rear.. couldnt figure it out..
then realised I forgot to replace one of the rear caliper bolts when I did the ABS sensor..
caliper was flipping up and smacking the inside of my wheel every bump  :laugh:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 25 July 2014, 08:57 »
Front suspension leg is sticking :grin:
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 25 July 2014, 10:09 »
Abit of wd40 sort that out?
*****MK4 GTI T*****
Offline xAntiVenxm
« Reply #8 on: 25 July 2014, 20:43 »
Depends what you mean by sticking dude
If you mean the top of the strut isn't compressing into the bottom and coming back out smoothly then need to check it hasn't blown and leaked all its oil.. If so then the strut will seize and it needs replacing.
If it's just just a bit stiff from road grime you might be lucky and cleaning it loads might save it.
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 26 July 2014, 12:24 »
Its fooked. So i need BOTH new front coilovers. I want a decent set. Anyone got a front set??
*****MK4 GTI T*****
