Author Topic: Rear brakes... What to do?  (Read 3159 times)
Offline rio_gti
« on: 23 July 2014, 23:57 »
Rear pads are running low, so for now might just replace them, but I would like to upgrade them with some larger ones.... Is there a way to put the old 288mm fronts on with modding for the handbrake? Or is this impossible?!!
Or are my only options the 256mm vrs, cupra ones? I don't want to use spacers (tt, r32 etc)
Oh and I have searched but not a lot comes up
Offline MoMartin
Re: Rear brakes... What to do?
« Reply #1 on: 24 July 2014, 00:23 »
Anything can be done... its just if you have the time and money to do it really. but yes, 256mm are the only option i believe (that are bolt-on anyway)
Offline gm8
« Reply #2 on: 24 July 2014, 10:00 »
256 from the anni or 180bhp model will go on without spacers.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 24 July 2014, 13:49 »
Apart from the obvious disc size what are the other different parts required to upsize? Are the calipers the same, I'd say a larger carrier is needed but aren't they integral to the rear beam on mk4's? Which then leads me to think the calipers vary?
Offline SI74
« Reply #4 on: 24 July 2014, 16:49 »
It's the carriers that are different. This is why people stay away from some of the TT ones and R32 due to the 4 wheel drive the carrier needs spacing to fit 2 wheel drive cars.
As Gm8 says the Anni or 180 model runs them in two wheel drive.
For the time and money you'd end up spending I'd hold out for ones from a 2 wheel drive car then bolt them straight on.
Offline gm8
« Reply #5 on: 24 July 2014, 18:02 »
calipers are different. vented disc vs non vented so much more inbetween caliper. Splash guard different too so will need replaced (can be cut away tho)
Offline shaft69
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline rio_gti
« Reply #7 on: 25 July 2014, 12:50 »
wow money can really be spent!!!
ill prob just do the 256 upgrade and be done with it
so what are my options?
Octavia vrs
v5 170
anni
what else?!!!
Offline gm8
« Reply #8 on: 25 July 2014, 15:19 »
auq engined golf also
Offline SI74
« Reply #9 on: 25 July 2014, 23:10 »
What's the Leon?
