Author Topic: Fault codes after changing can gateway  (Read 3322 times)
Offline dom
  • Back in a Mk4
« on: 23 July 2014, 21:01 »
Hi everyone,
Got another question about the MK5....I upgraded the can bus gateway to a newer revision to allow me to run an RCD510 without having battery drain problems. I swapped it over and coded it in fine, everything works ok but I've got an issue with rear fog and reverse lights.
These are the codes I'm getting:
Quote
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67DD5D1756980F26359-8032
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
Obviously the second 2 can be ignored.
Also this:
Quote
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001401339
   Coding: E78F0F060004181E001400001400000000087F075C
   Shop #: WSC 12345 123 12345
   VCID: 3A7BD46375AA42CE9A7-806F
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 12345
2 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
            012 - Electrical Fault in Circuit
01519 - Bulb for Back-Up Lights; Right (M17)
From the digging that I've done online it appears that the new gateway needs to be coded to a RHD car, I've tried this in the coding for the gateway module (ticking the RHD box). It says coding accepted, but if I go out of the module and back in it still shows the old coding. Any ideas?
Finally, I let the battery run flat when messing with the coding (rookie error!), and since have had this fault code as well which won't clear:
Quote
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1494645
   Coding: 0403000318070160
   Shop #: WSC 00375 210 82282
   VCID: E3C5C90722A0E306691-80B6
1 Fault Found:
012403 - Fuel Pump Circuit
               P3073 - 004 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 101641 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:42:02
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 46.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 9.271 V
Readiness: 0110 0001
Will that go away with time?
Dom
Offline Bellend
Re: Fault codes after changing can gateway
« Reply #1 on: 23 July 2014, 23:24 »
I had some coding that would not change (well it would but jump to old like yours) and haven't had the issue since buying a proper cable.
Where all my moneys went.
