Author Topic: Will this arb fit?  (Read 1501 times)
Offline Killer93yo
Will this arb fit?
« on: 23 July 2014, 19:44 »
Hello, bought from a friend a new arb and its from a 4mo bora 150hp diesel engine. 20mm and with powerflex bushes already installed on the arb.
question is that will this fit my fwd gti mk4? and what drop links can u use? got kw coilovers with the 4wd loopes
Offline Scott D
Re: Will this arb fit?
« Reply #1 on: 24 July 2014, 00:14 »
You'll be able to on using TT/S3/R32 droplinks with KW coilovers
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
