Author Topic: Stop/Start Issue  (Read 5597 times)
Offline mcmaddy
Re: Stop/Start Issue
« Reply #10 on: 25 July 2014, 08:43 »
I almost always have my air con on at either 22 or 21 and the stop start always works. It doesn't work if the engine is cold or the dpf is doing it's thing.
Offline LJS7
« Reply #11 on: 25 July 2014, 14:48 »
Thanks for the help guys. In my case it was because i had my fans on max (no air con) and set to low.
MK7 GTI | 3dr | Pure White
Offline p3asa
« Reply #12 on: 26 July 2014, 18:57 »
Re it not working if you have little fuel, mine is on 0 miles and still works!
Offline monkeyhanger
« Reply #13 on: 26 July 2014, 20:44 »
Cooling just a few degrees below ambient is rarely a bother for the stop-start unless you have the fan speed blasting. With the temp a few degrees warmer than the next best (27C) today, 19C and 2 bars on the fans was stopping the stop-start from cutting in. Upping the climate temp to 19.5C at a set of lights whist stationary and the car cut out.
Offline C2K
  • Northern Monkey
« Reply #14 on: 29 July 2014, 08:08 »
And i thought I played fuel light gamble!! Worst I got was 10 miles to go.  :grin:
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline p3asa
« Reply #15 on: 29 July 2014, 09:56 »
0 to go then drove another 12.
Then managed to get 51.53 litres into it.
Offline C2K
  • Northern Monkey
« Reply #16 on: 03 August 2014, 20:37 »
That's odd, I've had 50+ litre fills 4 times and never been anywhere near a zero prediction haha.
