Author Topic: Stop/Start Issue  (Read 5596 times)
Offline LJS7
Stop/Start Issue
« on: 23 July 2014, 14:03 »
Hi all
For some reason my stop start has decided to stop working. I know in the winter the engine needs to be warm enough but obviously that isn't an issue at the moment.
10minutes into a journey, engine oil temp 103 degrees, on a level surface, neutral with clutch up and nothing. Just the A with the line through on my MFD.
Anyone got any ideas please?
Thanks.
MK7 GTI | 3dr | Pure White
Offline peterdoherty
Re: Stop/Start Issue
« Reply #1 on: 23 July 2014, 14:07 »
AC may be on which would prevent it from cutting out
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline dereks
« Reply #2 on: 23 July 2014, 14:28 »
as above the air con is working hard with the heat so stop/start usually isnt available.
i usually switch it of anyway :whistle:
Offline corgi
« Reply #3 on: 23 July 2014, 15:48 »
There's an option under "Car" on the central screen which will tell you why Stop/Start is not engaging...
Corgi
Offline LJS7
« Reply #4 on: 23 July 2014, 16:37 »
Cheers guys. AC isn't on.
Ok Corgi i shall have a look.
Offline p3asa
« Reply #5 on: 23 July 2014, 17:53 »
Last time I looked to see why mine hadn't stopped it said "Engine needs to be running" No sh!t Sherlock  :grin:
Offline AlanH
« Reply #6 on: 23 July 2014, 20:27 »
Is Auto Hold engaged?
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline monkeyhanger
« Reply #7 on: 23 July 2014, 21:15 »
There are a number of reasons why stop-start wouldn't engage - usually it's down to aircon or active DPF regen going on (GTD). I can ge my stop-start to work with the aircon on if it's set to 19C, 2 bars of speed and recirculation is on. Any more aircon activity than that and the car will not cut out at a junction.
Offline JB GTI
« Reply #8 on: 23 July 2014, 23:03 »
Mine packed up last month and had to be replaced under warranty. Next time you start the engine check in the central display to see if you get an error message that pops up and the disappears a couple of seconds later.
One other thing. How much fuel have you got as it stops working if you are low on fuel irrespective of all the other things that could be causing it.
Now Gone: 3dr GTI Carbon Grey Performance Pack Dynaudio
Discover Nav Park Assist Rear Camera
Picked Up: 15th March 2014
Now Gone 3dr Golf R Lapiz Blue, DSG, Dynaudio, 19" Pretoria's, Discover Nav, Keyless, Rear View Camera
Picked Up: 1st March 2015
Now Gone Too: Mk7.5 Golf GTi Performance 5dr Indium Grey DSG Dynaudio 19” Brescia Alloys Vienna Leather Keyless Entry/Start Panoramic Roof 90% Tints Park Assist Rear View Camera Voice Activation Dynamic Lane Assist/DLA
Offline AlanH
« Reply #9 on: 24 July 2014, 18:28 »
Drove up to roadworks with temporary lights tonight. Aircon was on, set to Lo and two bars of fan speed. Engine stopped, but started again after 10 seconds.
