Author Topic: VW golf mk3 ABF starting problems  (Read 2191 times)
Offline little-ii
« on: 22 July 2014, 20:05 »
just bought a abf engined mk3 ready for a engine conversion into my mk2. when i bought it started fine every time. ive stripped the interior out and now when i go to start it everything lights up but when i turn the key all the way it makes a clicking noise. it wont start unless a battery booster pack is used and even the nothing happens first few turns of the key. once it starts if i turn it off sometimes it turns back on then sometimes it doesn't. tried using a different battery but no look. all i can think of it being is an immobiliser problem or a crankshaft sensor issue.
any help will be appreciated. thanks
Offline Screech16v
  • MK3 20vt AGU
Re: VW golf mk3 ABF starting problems
« Reply #1 on: 22 July 2014, 21:18 »
Could be a ignition switch problem,it's a very common fault,or starter itself.
Offline little-ii
« Reply #2 on: 22 July 2014, 21:20 »
could i try the one of my 90 spec mk2 and see if thats the fault
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 22 July 2014, 21:58 »
If the switch fits the plug then yes try it  :smiley:
