Author Topic: high emmisions on 2.0 8v AGG  (Read 2099 times)
Offline gaza2001
« on: 20 July 2014, 17:01 »
hi guys can anyone give me some advice as to what is wrong?
   DESCRIPTION             Limits       Actual Value
   Engine Oil Temperature     Min 60°C            NOT CHECKED          Temp gauge checked
   Fast Idle Test:                                                               FAIL
   Engine Speed          2500 -3000 rpm      2870rpm                                  PASS
          CO                       =< 0.30 %                  6.69%                                  FAIL
          HC                       =< 200 ppm            226 ppm                                   FAIL
     'A                           0.97 -1.03       0.820                                   FAIL
   Second Fast Idle Test:        FAIL
   Engine Speed          2500 - 3000 rpm     2793 rpm                                   PASS
     CO             =<    0.30%                     7.04%                                    FAIL
     HC             =<    200    ppm                    284ppm                                    FAIL
     'A                  0.97    -1.03                0.807                                    FAIL
   Natural Idle Test:        FAIL
        Engine Speed          450    - 1500 rpm     863 rpm                                   PASS
   CO             =<    0.50%                      8.08%                                       FAIL
   Overall Result :          Exhaust Emissions Test                                            FAILED
VW BUSH
Re: high emmisions on 2.0 8v AGG
« Reply #1 on: 20 July 2014, 17:44 »
CAT could have broken down or even be missing, Lambda sensor failed + a bunch of other things which could add to it.
Stick it on a code reader to see what that throws up first.
Is it smoking/using oil/losing water?
Offline gaza2001
« Reply #2 on: 20 July 2014, 17:59 »
cat is still on there, have changed the lambda sensor for known working one, as i have a cheap code reader and came up with code 0537, and still same code came up after the change and erasing the code?
VW BUSH
« Reply #3 on: 20 July 2014, 21:37 »
http://wiki.ross-tech.com/wiki/index.php/00537
I would start by checking the sensor cables back to the loom, then you need to work through the lists for upper and lower (vag com for better direction) :smiley:
Offline gaza2001
« Reply #4 on: 20 July 2014, 21:40 »
thanks will have another look tommorow..
