Author Topic: Strange high pitched fan noise when 1st starting  (Read 3086 times)
Offline Bfstrachan
When I start the car for the first time in the morning or after the car has sat for a while there is a high pitched fan coming in as soon as the engine starts. The engine is running fine and the temperatures are ok, but have not heard this before? Any one got an idea where to begin looking?
Thanks for help in advance :)
Offline james2
  • No scammers please.
Re: Strange high pitched fan noise when 1st starting
« Reply #1 on: 20 July 2014, 17:41 »
You sure its a fan , not your starter motor making the noise....
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline barrym381
« Reply #2 on: 20 July 2014, 17:54 »
My money would be on the sai  :smiley:
Offline lee1989
« Reply #3 on: 20 July 2014, 19:44 »
+1 mine does this every morning
Offline matty james
« Reply #4 on: 20 July 2014, 21:48 »
even a belt
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline Bfstrachan
« Reply #5 on: 20 July 2014, 22:30 »
Thanks for the responses! It's not a belt. Definitely a fan type noise. I ran the code reader and there was a code 16795 came up, but it was not constant. When I run the reader later in the day there were no codes. The code has to do with the SAI which is what you all are pointing out. Any suggestions on what I need to do and if it's ok running the car with this?
Again comments appreciated!
Offline barrym381
« Reply #6 on: 20 July 2014, 22:35 »
sure there is a guide to repair it kicking about will try find it for you  :smiley:
Offline Dalo Harkin
« Reply #8 on: 21 July 2014, 12:49 »
easiest to remove the SAI and do the delete, loads of threads
Offline Bfstrachan
« Reply #9 on: 22 July 2014, 08:05 »
Got the fix done to the SAI last night. Was not able to fully remove it from the bracket, but did manage to rotate the pump and change over from the rivets to the bolts. A few of the rivets had been rounded off and one of the hoses was not attached very well. Managed to tie grip the hose for a better hold. Will run it this morning and see if this has done the trick :)
Thanks for the help!
