Author Topic: Aum n75  (Read 1836 times)
Offline reedy20vturbo
Aum n75
« on: 18 July 2014, 18:32 »
Hello,
Just a quick one, I'm getting random big boost surges,  sometimes feels like youve caught the break by accident as you pull away if you get what I mean?when it does this you can hear it give a massive dump too, Some times the car pulls very well and other times its slow then half way through the revs it'll suddenly gain power like someone is flicking a switch if you get what I mean? I have replaced maf sensor and checked all hoses and I'm starting to think n75 valve. Is there a way I can test it or disconnect it to see if it makes a difference? No fault codes by the way. Cheers
Offline MoMartin
Re: Aum n75
« Reply #1 on: 19 July 2014, 01:17 »
found this online -
Quote
TESTING
Pull connector (1) off N75 valve (2)
Use a multimeter to measure resistance between valve contacts 2.
Spec ACV AJT AYC AYY = 25 to 45Ω
Spec AHY AXG AXL = 15 to 20Ω
Replace valve If spec not attained
If spec attained...
Switch on ignition and measure supply voltage at connector plug 1 and engine earth
Spec approx 12v. If spec not attained check wiring back to ECU.
Scrap that... just realised its for vw t4 / t5, so the readings will be different.
« Last Edit: 19 July 2014, 01:30 by MoMartin »
Re: Aum n75
« Reply #2 on: 19 July 2014, 07:46 »
That's amright mate, thanks anyway still stuck though :)
Offline Tezmax
Re: Aum n75
« Reply #3 on: 19 July 2014, 10:51 »
Had similar issues with mine so bought Nino's spare one but didn't cure it.
If you cant test or borrow one then i'll post you mine. (£15 if it works  :drool:)
Send it back if it dont :smiley:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Re: Aum n75
« Reply #4 on: 19 July 2014, 19:27 »
Yeah mate that'll be ideal, I'll message you my address if you give me your PayPal I'll drop you some money for postage cheers mate really appreciate it
