Golf mk4
Wazzzer
rear pads and discs replacement help
Topic: rear pads and discs replacement help (Read 1680 times)
Mark b
17 July 2014, 20:29 »
changing the rear discs and pads tomorrow ive got the parts, I could find a link on here so would anyone be able to tell me what size tools I will need as not sure help will be appreciated
Standard gti 2.0 115bhp 2000 w reg
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: rear pads and discs replacement help
17 July 2014, 22:05 »
you got yourself a caliper wind back tool?
A good tool kit should have everything you need, can't remember specifics but this should help
http://uk-mkivs.net/topic/46118-18t-golf-mk4-gti-256mm-full-rear-brake-diy-upgrade/
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
gm8
18 July 2014, 16:23 »
carrier bolts are 8mm allen bolts , and they will be tight, be careful not to round them or you will have a nightmare. caliper bolts are 13mm hex. The disc retain screw is phillips , and may be seized on . wd40 it before you go near it .
MoMartin
Here all the time
18 July 2014, 16:39 »
Quote from: gm8 on 18 July 2014, 16:23
This.
I accidentally rounded mine, and every attempt to remove it failed, luckily you can just about remove the disc without removing this bolt, if you wiggle it a lot. so i ended up just removing the disc and leaving the bolt alone.
Mark b
19 July 2014, 11:09 »
Thanks alot for the info but I bailed out and got a garage to do it yesterday I got the parts myself and the garage charged my £45 and monday he's doing my mot and a full service for £99
Golf mk4
Wazzzer
