Author Topic: AUQ problem please help  (Read 1495 times)
Offline w3ssr
  • Mk4 AUQ
« on: 16 July 2014, 12:04 »
ill keep it short. 1st & 2nd gear was nothin there so got it sorted but now theres a rattling noise and abit of a judder. It sound like its going to stall. Please help coz im proper f**K*D of with it now
Offline Dalo Harkin
Re: AUQ problem please help
« Reply #1 on: 16 July 2014, 12:33 »
sounds like the clutch is knackered
what did you sort to get it ok when there was nothing there
Offline mike1990
« Reply #2 on: 16 July 2014, 12:40 »
Does the rattling noise go away when you press the clutch pedal?
Or does the noise only happen when the clutch is pressed down?
Test the clutch see if it's slipping
« Last Edit: 16 July 2014, 12:41 by mike1990 »
Offline w3ssr
  • Mk4 AUQ
« Reply #3 on: 16 July 2014, 14:39 »
My local vw garage sorted it. They offered me a new clutch and slave cylinder at the time Wish id of took it now.the noise stops when u push the clutch in.
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 16 July 2014, 18:21 »
Release bearing/ thrust bearing.
Golf GTI ... What else would you have?
