Author Topic: 1.8T black smoke  (Read 4288 times)
Offline Scott-R
  • GoT BoosT!
1.8T black smoke
« on: 15 July 2014, 19:45 »
Setup - 1.8T AUQ running 550cc injectors and a Walbro fuel pump.... The revo map has reset back to default settings I.e. 1 out of 9....
Could this cause the rail to be highly pressurised and without the settings showing the correct fuelling ie 7 or 8 letting the ECU know that there's big injectors and causing over fuelling as the ECU will think there's small standard injectors on?
A fair bit of black smoke sometimes goes away completely and same with intermittent rough idle.
No codes showing on vag-com, brand new MAF and Lambdas not old atall maybe 3 months. Brand new turbo so not seals hopefully... Rare one.
I have done a lot of research on this already this week but can't find simple answer and the only person who can put settings up to where they should be is on holiday...
Also I have a brand new N75J valve but it doesn't look the same as the standard valve any decent diagrams on how to install it correctly?
I will update if I sort this as all other threads seem to leave it at a dead end.
Golf GTI ... What else would you have?
Offline topher
  • Administrator
  • fully functioning
Re: 1.8T black smoke
« Reply #1 on: 15 July 2014, 20:11 »
under what conditions are you seeing the smoke? on boost, overrun, idle etc..?
Offline Scott-R
  • GoT BoosT!
« Reply #2 on: 15 July 2014, 20:25 »
Idle and just as I take off.. Goes away when driving unless I'm sat cruising, then when I go again a small puff.
Also it comes and goes on idle sometimes it's not there and only once fully heated up.
« Reply #3 on: 15 July 2014, 23:55 »
Black smoking is excess fuel being burnt off
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 16 July 2014, 00:22 »
Wayne that would mean my first post was correct and the amount of smoke relates to the massive difference in what the ECU thinks is happening.
It will think there's stock injectors and be running them flat out, but intact there very big and flooding the engine.
Offline golfhappy
« Reply #5 on: 16 July 2014, 08:20 »
you're on the right track, think when you're on idle it will be on closed loop...running in lambda mode from the upstream sensor feeding back to the ecu. When you then take off,accelerate it's getting a glug of fuel from the large injectors and over fuelling for that moment and ecu playing catch up...black smoke(excess fuel). When you settle the throttle on cruise closed loop again until you hit the pedal again..black smoke. Maybe i'm on the wrong track :smiley:
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
« Reply #6 on: 16 July 2014, 09:44 »
Yep that is what I think is happening.
Offline Scott-R
  • GoT BoosT!
« Reply #7 on: 18 July 2014, 18:48 »
Map is set back onto the car and still massive over fueling  :sick:
No fault codes showing at all and Lambdas and maf are new?
Offline barrym381
« Reply #8 on: 18 July 2014, 21:46 »
get the car to r-tech mate they will set it up right  :smiley:
